ebay crossdrilled rotors
- babyblueMX3
Hi everyone, just wanted your opinions on thoseebay crossdrilled rotors they are reserves at 85 USD (front set and rear set)..Does it worth it or it's a rip off?
Thanx for any comments
RIP 400whp ZE-T MX-3
Re: ebay crossdrilled rotors
I think they're worth it. I haven't bought any yet, but they look ok and the seller is reputable. I think you'd be hard-pressed to get a set of non-cross drilled rotors for $85, so I think these are a deal.
Could someone fill me in as to what these are?
- babyblueMX3
here are some info on the crossdrilled ad
-18 to 25% more braking power!
-Superior engineered Cross-Drilled designs vent brake gas!
-Increased ability to dissipate heat!
-Reduced brake fade means shorter stopping distances after repeated stops!
-Improved wet weather raking design sweeps water away from between the rotor and the pads!
-Each hole is radius-chamfered to produce a smooth transition at the edge off the hole diameter, which reduces stress risers and the occurrence of fractures!
-Unlike slotted rotors, cross-drilled are very friendly with brake pads!
-The rotors are designed with a directional pattern, so a pair consist of a left and a right rotor!
- babyblueMX3
As anyone bought them, and if so did you have any problems with the seller..I would like to hear from somebody who bought them..Thanx
How are cross-drilled rotors going to increase your braking power? there are holes drilled into them which means less surface area for the pads to slow your car down with. <p>From waht i've learned. Cross-drilled and slotted rotors are for looks more than function. They ARE better for dissipating heat, but that is only if you are hardcore racing. If you are driving on the street normally, you won't notice any difference.<p>
If you want nice looking rotors, that is a great deal! I'm not sure of the quality, but they are the same price you'd pay at autozone for replacements, so why not? I was considering buying these myself.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Cross drilled and slotted rotors increase braking power because it keeps the pads and the rotors cooler during braking. Any time you increase the power output of the engine, you will want to upgrade the brakes. If you're going faster you wanna be able to stop as well right? I'm not saying with these rotors you will be able to go from 60-0 in .3 seconds. And No, the will not make you stop any quicker than with regular brake rotors. What they are for is when you stop repeatedly your rotors heat up rapidly. These help disipate heat while the brakes are not being applied, as well as keeping it cooler while the brakes are applied. In effect making you stop better and more often
than without. If you don't have significant power added to your car, there is really no reason for these except for cosmetics.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
![Image](http://www.angelfire.com/ut2/vizualxtc/images/mx3_2.gif)
![Image](http://www.probetalk.com/forums/images/smilies/icon_spongebob.gif)
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
hmmm the guy is in ontario, and its wierd because a guy at work was telling me the other day about his friend that makes cross drilled rotors in his garage, has boxes made up and everything, and he sells them on ebay! if thats him maybe i can get a deal for the mx-3er's
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by sureshiit:
hmmm the guy is in ontario, and its wierd because a guy at work was telling me the other day about his friend that makes cross drilled rotors in his garage, has boxes made up and everything, and he sells them on ebay! if thats him maybe i can get a deal for the mx-3er's<hr></blockquote><p>i just emailed him to find out where he lives
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
- monty73741
IF XDRILLE & SLOTTED DONT WORK SO WELL THEN WHY ARE THEY ON STOCK PORCHES
I GOT A SET THEY LOOK GOOD STILL NEED TO INSTALL EM
Jason Danaher
Please Help Support MX-3.com
- Custommx3
- Site Administrator
Yes your lowering your braking surface but drilling actually increases surface area allowing for better heat dicipation and reducing "Glazzing". This is good for hardcore drivers but less warpage occurs too. (Heat+friction causes warping) Less heat.. less warp.
