Coolant Pipe on KLZE
Posted: July 9th, 2003, 12:15 am
by SimonPK
Has anybody any idea what the small coolant pipe is next to main radiator pipe on the front rightside of the block is? I am looking for something to connect it to but there is no equivalent on my old K* to compare it to,<p>thanks
Re: Coolant Pipe on KLZE
Posted: July 9th, 2003, 12:27 am
by Zoso124
Gotta be a little more specific, but I'm guessing your talking about the coolant line that goes down to the Oil Filter cooler assembly.
Posted: July 9th, 2003, 12:51 am
by SimonPK
Sorry about the lack of detail - the pipe is a small diameter around 1/4" & is level with a large pipe 1 & 1/2" diameter. The large pipe goes into the radiator on the cooling fan side. The small pipe goes back into the thermostat housing and then back under the TB where I lose sight of it!<p>My KLZE came from an automatic and has the round intake neck so I was wondering if this pipe was something to do with the ATX so is not needed. <p>thanks again
