what's the right VAF for KLZE
I seen so many posts on the swap I can't figure out what VAF to use.<p>I'll be swapping in a KLZE in 2 weeks time and I would like to know if I can use my K8 VAF which has JE50 written on it. Will anything go wrong as I have seen posts saying this causes a CEL for "too rich too lean"?<p>If the JE50 is not right which one do I need to use?<p>thanks.....
dkrangers
Re: what's the right VAF for KLZE
I'm swaping over the forth and plan on using my K8 VAF. Good luck with your swap.
- Custommx3
- Site Administrator
the JE50 (mx-3 GS stock) is what comes on a KLZE in japan.
thanks for the quick replies! That crosses one more unknown off my list.<p>Just so everyone knows I managed to get a KLZE (MS8) at Foreign Engines in Lynnwood, WA for US$849 - they had 3 other KLZE's there on Tuesday - all straight necks though - all looked very clean and the compression tag were good and high and even on them all. So with duties & freight I paid CAD$1400 delivered to my garage in Vancouver, BC. I asked about freight to the East and they reckon US$200 pretty much covers anywhere in the US, for Canadians you're on your own from the border!
- mazdasly75
The thing that will determine wich VAF you need isn't the engine..<p>It's the ECU! if you plan to run a KL03 ECU then you need a KL02 VAF. If you're keeping the K8 ecu. You need the OEM VAF JE50. You know your engine will suck gas as a cow suck milk?? It will also have, when closed loop MAP, a period that the 2.5L will run lean and will overheat??? Plan on swapping a 2.5L ECU or a new burned chip with 2.5L fuel MAP.<p>I would consider for a KLZE ECU wich keep the JE50 VAF and you'll get a better gas millage as well.<p>Good luck
1996 MX3, KL, stock internal, T3T4, 10psi, tial wastegate and blow off, 450cc injectors, 255lph, 3" mandrel bend exaust, 67mmTB, megasquirt II, launch control/flat shift, boost controler, 4bars MAP 16x16 built in, 300whp
Thanks for the advice - how much should I pay for an ECU to suit?
- Custommx3
goto the buyer/seller feedback forum and look for Lazzie. He can get u one. Nt sure on the price, but I know it should be <300 bucks.
- babyblueMX3
Engine land for 200 CND...and it's not far from Trois-Riviere either..I'm ordering mine there
RIP 400whp ZE-T MX-3
- babyblueMX3
Oh made a mistake I tought the guy who wanted the ecu was from trois-riviere...Well engineland is located in Montreal (Quebec)...As far as I know it's the cheapest place to buy it.
- mazdasly75
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by babyblueMX3:
Oh made a mistake I tought the guy who wanted the ecu was from trois-riviere...Well engineland is located in Montreal (Quebec)...As far as I know it's the cheapest place to buy it.<hr></blockquote><p>Nah!<p>I have a SDS stand alone ecu now.
Gro Harlem
Wow, glad I saw this post b/c i was about to ask this question just now.<p>SO let me get this straight, with the KLZE motor, you can run 3 different ECU's: K8, KL, and KLZE. And two different VAF's: K8 and KL<p>So the KLZE VAF is the same exact one as the K8?<p>So...that would mean, to run a KLZE properly with a K8 ECU you'd need a KL VAF (to get better gas mileage/performance), and if you run a KLZE with a KLZE ecu, you'd need the K8 VAF right?<p>Which would also lead me to assume, if for some reason you run your KLZE with a probe or mx6 KL ecu, you'd want the KL VAF with it to have it run properly.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
actually you can run the kf ecu too... but yes
ECU/VAF
k8/k8
k8/klde
klde/klde
klde/k8(don't do this)
klze/k8
klze/klde(don't do this either)
kfze/k8
ECU/VAF
k8/k8
k8/klde
klde/klde
klze/k8
kfze/k8
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
mazdamaniac
Just to add to the confusion -
I could NOT get the engine to operate correctly with either the K8 ECU or the KL ECU and the K8 VAF on a KL.
The only VAF that would work correctly was the KL VAF with either ECU.
SI,<p>so theres a place in lynwood that has ZE's for sale? that is so awesome! if i read your post correctly, they should have 2 more KLZE's with straight-neck IM's for around $850? e-mail me.
92 Mazda MX-3 GS: blaze red, bone stock, and daily driver
86 RX-7 GXL: '94 LT1 V8, 6 speed tranny, scary fast. SOLD
93 Mazda RX7 R1 LS1/6speed... 75% complete
http://www.cardomain.com/id/mattsterrx7" onclick="window.open(this.href);return false;
^link to my V8 swap page
