compression check - what would be expected?
Posted: June 3rd, 2003, 11:48 pm
by kneel
I've put a tentative offer on a 92 , V6 , with 200KM on the engine, conditional on good results from a compression check. <p>What sort of reading should I be looking for? <p>I scanned previous articles, but most talk of 9:1 and 10:1... I think I'm looking for PSI? <p>Thanks
Re: compression check - what would be expected?
Posted: June 4th, 2003, 8:53 am
by andy
more importantly they should all be close to each other. if they all read 180 psi plus or minus 5-10 psi then things are good. if one or two cylinders are much lower than the other 4, meaning more than 20 psi, then something is not good.
There are a number of ways to measure compression. which way you do it will change the peak #'s. just be sure to check all 6 cylinders consistently the same way.
Andy P. 93 GS
