Page 1 of 2
Mx-3 Flywheel on Mx-6 Clutch for KLZE
Posted: June 3rd, 2003, 12:50 pm
by Nd4SpdSe
i've think i've decided to get the ACT Z62-HDSS Clutch for the Mx-6 to use on my Mx-3 for the KLZE swap, but now what i want to know is that if there's any problem with the Mx-3 Flywheel matching with the Mx-6 clutch
Re: Mx-3 Flywheel on Mx-6 Clutch for KLZE
Posted: June 3rd, 2003, 1:46 pm
by Custommx3
I dont believe so, many Probers use mx-3 flywheels, but just have them shaved down.
May wanna ask some of the probe guys who have mx-3 flywheels. My only concern is that the 2.5L clutch MAY be a few MM bigger than the mx-3 one. But that may not matter.<p>[ June 03, 2003: Message edited by: Custommx3 ]</p>
Posted: June 3rd, 2003, 4:52 pm
by Nd4SpdSe
i think david coleman has an mx-6 cluth, but he doesnt say that he uses the mx-3 or mx-6 flywheel. I read that the mx-6 clutch is 10mm larger, but noone has said what flywheel they use, i know its recommended to use the mx-3 since its lighter, and get it down to 13lbs.<p>
I was thinking (and understood) that the mx-6 Z62-HDSS clutch can handle more power than the mx-3 Z62-HDSS, so i can put more power (turbo, nos, whatever), and not need to get a racing clutch and worry about daily driving.
Posted: June 3rd, 2003, 6:48 pm
by lazzyie
The flywheel and clutch fit perfectly I would recommend getting a couple pounds shaved off of the flywheel as well as getting it resurfaced. The holding power of the ACT clutch is 260 ft of torque if I remember right. Good luck.
Posted: June 3rd, 2003, 7:17 pm
by Nd4SpdSe
do you talking about the mx-3 flywheel and the mx-6 clutch? I hope so..<p>That setup should work better than the mx03 ACT clutch but not be as rough as any of the racing setups right?
Posted: June 3rd, 2003, 7:26 pm
by lazzyie
Alright I don't know how to make this any clearer than this:
On my car with a Millenia KLZE I have the
Z62-HDSS Mx-6 clutch you want to buy and my 1992 215mm Mx-3 flywheel that I had milled down to 13 lbs and resurfaced the clutch dropped right in; the 94+ models of the Mx-3 have a 225mm flywheel. So far(knock on wood) it drives nicely!! I have no sloppy shifts but not jerky feeling either.
Posted: June 4th, 2003, 2:20 am
by Nd4SpdSe
k, so the mx-3 clutch works with the 1992 flywheel, and works nicely, just checking...the "good luck" just threw me off got me worried.<p>[ June 04, 2003: Message edited by: Nd4SpdSe ]</p>
Posted: June 5th, 2003, 7:30 am
by GuidoBiRiChiNo
I have a MX-6 clutch and a K8 flywheel too, no problems encountered.
Posted: June 5th, 2003, 11:25 am
by Nd4SpdSe
92-93 or 94-96 Flywheel?<p>[ June 05, 2003: Message edited by: Nd4SpdSe ]</p>
Posted: June 7th, 2003, 7:30 am
by GuidoBiRiChiNo
As far as I know, 92-93 models have 215mm clutch and flywheel, and 94+ models have 225mm (same as MX-6).<p>I have a 92 fw and an MX-6 clutch.. the shop that did the job didn't tell me anything about putting them together.
Posted: June 7th, 2003, 10:19 pm
by mxer4eva
where did you guys who have the mx-6 clutch pick yours up at? Was it at corksports or some other vendor and how much? I'm just want to make sure i get the best price thats all.
Posted: June 8th, 2003, 4:32 am
by Nd4SpdSe
im ordering mine locally
Posted: June 8th, 2003, 10:08 am
by OsoSlo z28
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by mxer4eva:
where did you guys who have the mx-6 clutch pick yours up at? Was it at corksports or some other vendor and how much? I'm just want to make sure i get the best price thats all.<hr></blockquote><p>www.advancedclutch.com
www.groupbuycenter.com
Posted: June 8th, 2003, 11:46 am
by Sean Mandell
honestly, If you want to turbo your mx-3ze then you can throw that daily driver idea out the window. go with the stage 1 clutchmasters for better pedal feel and daily driving.
Posted: June 8th, 2003, 11:49 am
by Nd4SpdSe
Turbo ZE wont happed for prolly 2 years anyway, so its no big of a deal, plus i'll have a 2nd vehicle next year anyway.<p>But what makes a Turbo ZE different for daily driving over a stock turbo car?<p>[ June 08, 2003: Message edited by: Nd4SpdSe ]</p>
