Ok..I was sealing everything back up on the KLZE when I noticed the rear valve cover has a multi crackle reflection ....under closer examination most of them go all the way thru the cover and appear on both sides. They look like stress fractures. The valve cover I am talking about is the one the intake covers (rear one). I thought no big deal, I would just remove the one from the K8 and place in on the Ze as a replacement....guess what same Frelling thing! cracks all over, but much worst.
![Image](http://www.dragonflybodyworks.com/temppics/cracks1.gif)
![Image](http://www.dragonflybodyworks.com/temppics/cracks2.gif)
<p>Do you think this is normal ...Or do you think it is heat related ? have you see this before ?<p>Thanks
Cage
