kl31 ECU
kl31 ECU
I received my ecu from Lazzyie yesterday !
I'm so happy !!!!
My milleage improved with 70% (believe it or not)
Cold start is perfect.
Sounds like a normol mx-3 instead an old harley fatboy.
No more unburned fuel and lots of smoke.
The idle is stabile etc (to much to mention)<p>one issue I found.<p>I saw my engine is getting hotter than with the k8 ecu.
Is this because of the EGR ?
I know egr support is not there on the kl31.
If this is the case, anyone got an solution?
Anyone got the same thing?
Do I need a bigger radiator or something?
Please let my know.<p>
And for Lazzyie : Thanks again pal !
You made me realy happy.
And also, thanks for the trust !<p>Dennis
I'm so happy !!!!
Re: kl31 ECU
anyone got the same experience?
Running without EGR on the kl31 ecu , engine is getting hotter than before?
- Zoso124
Re: kl31 ECU
Never heard of anyone trying to run an OBDII ZE ecu unless your converting your car to OBDI.
Mike Evans
Gone:
Gone:
Re: kl31 ECU
There are no OBDII ecus as OBDII did not exist in Japan. You can get a totally different ecu/maf setup that comes out of the Japanese Millenias if you really want to...
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
Re: kl31 ECU
Oh... I saw the other topic and I said yes on your question about OBDII.
Sorry about that !
OBDI=yes
Sorry about that !
OBDI=yes
Re: kl31 ECU
Sorry about that !
OBDI=yes<p>but still I have the question, why is the car temp higher than it was with the k8 ecu ?
Sorry about that !
- Aston Wards
Re: kl31 ECU
is your temp stable and hot, or is it overheating? Maybe it's just a coincidence that it's happening now?
91 Eunos Presso KF-ZE
89 Nissan 300ZX TT 2+2
90 Nissan 300ZX TT 2+0
Re: kl31 ECU
No, the temp is stabile.
It is not overheating, It is just warmer than it was with the k8 ecu.
Re: kl31 ECU
my temp is just below the 1/2 way mark. It has always been there
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
Re: kl31 ECU
IT's normal because the KL-ZE not use the EGR and eventually the ecu of KL-ZE don't drive the EGR. The EGR it's use to lower the temperature of they engine for avoid low NOx. So in Japan don't have the same emission text
MX-3 GS 2.5l A-spec BRÜLLEN CAT BACK EXHAULT 2 1/4'',PRM cold air intake, Swaybar Whiteline 22mm, Upper Strut Mont MAZDASPEED, COIL H&R, Shock KONI AJUSTABLE,B&M Short Shifter,Bronzoil shifter, Mag 16''pneu G-Force 205/45/16, Strut Bar av/arr
Re: kl31 ECU
Thought so.<p>Thanks !
