Does The Tranny Need To Be Changed for a KLZE Swap?
I know the its recommended to change the clutch, but how will the 5spd tranny on the 1.8 Mx-3 hold up under 2.5l power?
Re: Does The Tranny Need To Be Changed for a KLZE Swap?
Same trans is used in both Probes/626/MX-6 and MX-3.
Would there be any reason to get it changed?
Should i once the engine is out or does it make no difference?
the only reason you would get it changed is if you want the ZE tranny which in some cases comes with a LSD.
Shaun Newman
LSD?
Limited slip differential....= no more one wheel wonder burnouts. Both tires will spin at the same time.
My Cardomain site
My Cardomain site
- Zoso124
If you get a LSD let us know where you found the axles since they have more splines on them.
Mike Evans
Gone:
Gone:
