Cam regrinds
Cam regrinds
Can I get my cams regrinded and throw them in the ZE? Thanks all.
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
Re: Cam regrinds
Certainly!
Re: Cam regrinds
Wow I am a retard. DO NOT POST WHEN TIRED!!! I mean can I get my K8 cams regrinded and throw them in the ZE?
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
- Zoso124
Re: Cam regrinds
Yes you can use your K8 cams as cores to have them grinded to what ever you want. Two people that do them is Mike Seli from on Probtalk who sells a few different cuts that range from $375 to $470 IIRC. The other is Interprep tuning which has two regrinds, a Street and a Race profile which are around $600 and I know the Race profile require stiffer valve springs and shims ($300) (Not sure if they are need on the Street grind) which are not needed with Mike Seli's cams.
Mike Evans
Gone:
Gone:
Re: Cam regrinds
nah its cool ill spend $150 at my friends shop thanks Mike.
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
- Zoso124
Re: Cam regrinds
Sweet, let us know what profile your cutting them at what kind of improvement you get on the dyno.
Mike Evans
Gone:
Gone:
