ms8 manifold
MXKreepscort
ms8 manifold
Post by MXKreepscort »
I will beg etting an ms8 intake manifold soon and i was wondering from wich millenia engine it comes from, the 2.5 or the 2.3, I would think the 2.5 but im just making sure. thanx
Sonicxtacy02
Re: ms8 manifold
Post by Sonicxtacy02 »
definitely the 2.5. The 2.3 is completely different.
Shaun Newman
MXKreepscort
Re: ms8 manifold
ok, now I could use the intake manifold from the US millenia correct? or is there a diference in the j spec one?
MXKreepscort
Re: ms8 manifold
anyone?
IanL
Re: ms8 manifold
Post by IanL »
I think you'll find that the jspec doesn't have the fitting for the EGR valve. But you can drill & tap (not sure where) if you want to retain EGR. If I haven't missed something, the export spec manifold would be the more straightforward job.
pelado
Re: ms8 manifold
Post by pelado »
If you get a Jspec MS-8 manifold, then it has a block off plate on the backside of the manifold where the US Millenia has an EGR valve bolted to.
MXKreepscort
Re: ms8 manifold
ok, I'm thinking of getting the US one then, but is there any diference in hp gains between the 2 intake manifolds?
Zoso124
Re: ms8 manifold
Post by Zoso124 »
No
Mike Evans
Gone:
MXKreepscort
Re: ms8 manifold
ok, thnx
