Hi all.
Planned the engine swap this weekend but the delivery of parts is to late !
I want to use my stoch clutch for a while.
Anyone got experience with it on the kl-ze (eunos800)
Also an important question: the multibelt of the eunos, is that the same belt as the stoch one on the mx-3? same as water pomp belt and timing belt.
Are they the same or are they the same as the kl03 belts?
NEED URGENT ANSWER !!!
please help
problems swap again
Re: problems swap again
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by leiden:
Hi all.
OK, If you are buying a new stock clutch buy the klo3 clutch, it's bigger and it bolts right up. I had the flywheel resurfaced (recommended) and the deck lowered 3mm for more spring pressure.<p>not sure aboot timing belt but my k8-o3-ze were all the same
please help<hr></blockquote><p>
answer is in quote<p>[ March 13, 2003: Message edited by: aaron the hic ]</p>
Hi all.
13.023 @ 105 mph
Well... i want to use the mx-3 clutch for a little while.
When the Stage II clutch arrives I will put it in.
That should be possible wont it?<p>Okay, so for what I understeand, the belt should be the same?
