Clicking noise around turns
Posted: February 26th, 2003, 7:04 pm
by Guest
Ok my car is just a pain in my *** , nothing but problems, and today theres a new one! yay! ok when i go around turns i get this loud clicking noise coming from my front left wheel, any ideas? I thought it was just ice because there was alot of build up around my tires, but i went and took it all off at the car wash. Of course I might have missed some i couldnt see but Im thinking its probably mechanical. Any ideas? Thanks laot guys.<p>Timothy Dawson
Re: Clicking noise around turns
Posted: February 26th, 2003, 7:15 pm
by cashmoneyspeed
CV Joint. I'll bet if you look at the inside of the rim, there is a bunch of black grease on it and your cv boot has probably been torn for awhile.
Posted: February 26th, 2003, 7:16 pm
by Q187
CV Joint. You can go to Autozone and buy rebuilt ones for like $60 a pop. If you have any mechanical experience, you can put them in yourself. Pretty easy job. Even though only one is clicking, go ahead and change both, the right one will start wearing down sooner or later.
Posted: February 27th, 2003, 12:57 am
by Guest
awesome guys thanks alot for the help!!
Posted: February 27th, 2003, 3:38 am
by Nd4SpdSe
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Q187:
CV Joint. You can go to Autozone and buy rebuilt ones for like $60 a pop. If you have any mechanical experience, you can put them in yourself. Pretty easy job. Even though only one is clicking, go ahead and change both, the right one will start wearing down sooner or later.<hr></blockquote><p>
Soo, soo true, i changed my left one in late November and about almost 2 months later, the right started doing it...<p>I got my replacement ones at canadian tire, remanufacturered with a lifetime warranty, cant do wrong with that
<p>[ February 27, 2003: Message edited by: Nd4SpdSe ]</p>
Posted: February 27th, 2003, 5:46 am
by sep42
How much did the Canadian Tire charge you?
Posted: February 27th, 2003, 7:17 am
by millionflame
I have the same problem and it's my driver's side tie-rod end. So, it not ALWAYS the CV joint people.<p>Both my boots are perfectly fine, and the joints.<p>~A
Posted: February 27th, 2003, 12:36 pm
by sheller
It could also be a loose/worn sway bar linkage. Unfortunately clicking is a pretty loose term. The best bet is to check under there and see if you can find anything. Do you see grease? Are either the tie rod or sway bar loose? All of the above?
When was the last time any of those items was replaced?
Don't feel too bad about it seeming like one thing or another. Around November last year I dropped in a new engine and at the same time did a lightened crank pulley, a new water pump, and a new timing belt. Two weeks later new O2 sensors and sway bar linkages. The day after that the transmission went out. $4k in repairs in a month. Anyway, good luck with the search.
Steve<p>[ February 27, 2003: Message edited by: sheller ]</p>
Posted: February 27th, 2003, 2:25 pm
by Custommx3
NAPA! lifetime warranty on cv's.
Posted: February 27th, 2003, 6:18 pm
by mattster
Ya ive got the clicking noise too... most definately CV joints. The parts are relitively cheep but after calling around, it is apparent that they like to slap on a "core charge" which will be refunded on return of the old joints. so it totals like $300 but you will get $150 back or whatever.
