klze Q
klze Q
I heard that the klze manifold doesnt have an EGR tap and thats why it might not pass emissions tests, so does the ms8 manifold have an EGR tap?
Re: klze Q
MS8 mani has a EGR, but the exh mani doesnt, which doesnt matter cause you'll use your K8 exh manifolds anyways.
David Coleman
Re: klze Q
Can't you get an aftermarket exhaust manifold for a KL, and they have EGR taps too
- Buff1110
Re: klze Q
yes u can get after market headers to use instead of the stock ones and they will have egr on them, BUT those headers are about 7inches longer than the mx3 ones so either A. they cut and reweld the collector (i think thats what its called) to make it shorter. B. your cat gets pushed back to make room for the extra length.
Dan
02 Tacoma TRD - Daily
Re: klze Q
You would have to use a Millenia EGR valve on the curved neck manifold, The KL,K8 EGR's dont fit.<p>last time I checked it was $400.00 CDN
Yes, I AM a bastard
Yes, I AM a bastard
Re: klze Q
EGR benefit is mainly to reduce Oxides of Nitrogen. If your emissions test does not include NOx (ours does not in UK) you might not want to bother.<p>I've seen previous posts from KLZE owners who have passed emissions with no EGR.
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system![Smile :)](./images/smilies/icon_smile.gif)
Re: klze Q
for the aftermarket exh mani with the EGR, who makes them, and are they for the mx3 or mx6? I've seen some for the mx6 but I havnt found any for the mx3.
Re: klze Q
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by MXKreepscort:
for the aftermarket exh mani with the EGR, who makes them, and are they for the mx3 or mx6? I've seen some for the mx6 but I havnt found any for the mx3.<hr></blockquote><p>No, no one makes headers specifically for the MX-3. MX-6/626/Probe headers will fit but some mods have to be made (shorten exhaust pipe leading up to header outlet).
