KLZE seems to be gettin worse
davidosk024
Post by davidosk024 »
I took it to the shop today,<p>the 2 cooling fans that are constantly on need to be looked at by an auto electrician which they didnt have onsite... so on monday that gets looked at.<p>I have also noticed that the RPM needs seems to not be as quick to rise as it was when i first put in the ZE ecu??<p>any reasons as to why the engine might feel sluggish like this??
In
Eunos 30x, v6
KL-ZE, 2.5in exhaust, K&N intake
Unichip, LSD, 13lb flywheel, ACT2 clutch, NGK iridium Plugs, Top Gun Leads...<p>Goin In
Cams, Headers, TB, Extractors,
Bored to 2.8, Mazdaspeed Struts, Mazdaspeed strut tops,
Mazdaspeed swaybars, Eibach springs, Cusco Adj. Strut tops, Body kit, Altezza lights, Short shifter, Crossdrilled rotors and Calipers from AP racing, Braided brake lines, Braided clutch line, Mazdaspeed steering wheel, Mazdaspeed Leather shift knob,
aaronthehic
Re: KLZE seems to be gettin worse
Post by aaronthehic »
thermostat??? :shrug:
13.023 @ 105 mph
Sonicxtacy02
Post by Sonicxtacy02 »
When i had tps problems my fans were constantly on and the rpms didnt rise as they should. You might wanna try following the TPS reset procedure.
Shaun Newman
