klze intake manifold
Im planning on swapping in the klze soon and was wondering if i would pass emissions inspection with its intake manifold... I heard that you dont pass with it and to use the aspec manifold instead, now wich manifold should i use, the 1.8, or the kl03's 2.5, also wouldnt I not get the full 200 horses if i use one of these manifolds instead of the klze's?
Re: klze intake manifold
Yes you would lose hp approxamatly 6hp. Depends on your state laws if you pass. I know a guy down here that used the ze manifold on his probe and passed fine with a new cat, 02 sensors, and the Aspec computer.
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
You can't use the KLZE in an MX-3 cause the TB will hit the brake master cylinder. Use the US Millenia manifold, it has the same size passages as the ZE and a curved neck like the K8.
so with the millenia manifold I would get the full 200 hp correct?... is this what everyone with an mx-3 does?
try and get a kl-ze with the ms8 intake manifold
if you get the mx-6 version kl-ze i would see if you can get the neck of the manifold cut and welded but I did this to my mx-6 version manifold it worked until i could find a ms8 manfold<p>mike
sounds like a good idea, now I heard that the klze manifold doesnt have an EGR tap and thats why it might not pass emissions tests, so does the ms8 manifold have an EGR tap?
Spaking of the MS8 I.M.. Does anyone know or have the resources to indicate how it is installed on a KL=03?
I just bought one off ebay, just cant figure out the vaccumm line conections.<p>thanks
OSKY
95 MX-3 GS ZE Turbo: MSnS-extra, AEM WB, Blitz boost controller, MSD 6A w/ Blaster2 Coil, ZE disty, Redtops @ 550, Walbro 255, Garrett T3/T04E 60 Trim w/ .63 A/R, 38mm Deltagate Mark II @4psi, FMIC, Apexi BOV, CM Dual friction, 4-6.25 Kickers, 2ch Alpine V12. That's Alll.
http://www.pakfeifertuning.com
I know., the grammar is poor. Sorry.
OSKY
My Chilterns has a good vacuum diagram, I can scan it if you like? <blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by EZ_4_FUN:
I know., the grammar is poor. Sorry.<hr></blockquote> One m in imitate
Id appreciate it !!!<p>email it to me at oscardevesa@sympatico.ca <p>Thanks!!!
OSKY
if you would be kind enough, e-mail it to me as well at treckrtj@yahoo.com Thanks a lot!
