LSD and some extra sensor
Yo,<p>Got an lsd that's going into the car next weekend, but a question arised: what is the sensor on the tranny? I can't tell you the actual position because I'm not in front of it, but it's not on the stock one...<p>any clues?
Re: LSD and some extra sensor
Neutral switch?
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system![Smile :)](./images/smilies/icon_smile.gif)
There's a neutral switch on the stock tran, it's another sensor altogether...apparantly!
Is there a cruise control sensor on the tranny?
Marc
Marc
There's also a back-up light switch.
