OK,
The only thing left for me to do is send the check to Sun Engins. I told them I needed an KLZE with KL31 1A1 Cams but he told me all of the KLZE's Have them. I said I needed the curved neck intake because the stright neck will not clear the hood and or the master break cylinder. Is there anything else I should add to help explain that a Probe KLZE will not work for my needs ?<p>Thanks
Question about KLZE
Re: Question about KLZE
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Cage:
OK,
The only thing left for me to do is send the check to Sun Engins. I told them I needed an KLZE with KL31 1A1 Cams but he told me all of the KLZE's Have them. I said I needed the curved neck intake because the stright neck will not clear the hood and or the master break cylinder. Is there anything else I should add to help explain that a Probe KLZE will not work for my needs ?<p>Thanks<hr></blockquote><p>You need a Eunos 800 intake if I recall well.. But the v6 guys will give you that info
OK,
Manach
Ex Mx'er with a Mx-3 1993..
Still in the Mazda Familly with :
-Mazda Rx-7 1987 GXL (Not running, one housing does not compress)
-Mazda Protege MazdaSpeed 2003.5 Titanium!
Still got 3 Engines!
- B6-ZE : Turbo Festiva project (Waiting donor car)
- BP-DE : Trader for a B6-ZE 1994 for parts upgrade in the Festiva project
- K8 : For sell. Pm me for info!
Once you go turbo, you can never go back!
to my knowledge i thought that the curved neck kl-ze only cam with kl-03 cams and the mx-6 version with the intake that doesn't fit on the mx-3 came with kl31 cams
- Custommx3
- Site Administrator
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Smokin mx-3:
to my knowledge i thought that the curved neck kl-ze only cam with kl-03 cams and the mx-6 version with the intake that doesn't fit on the mx-3 came with kl31 cams<hr></blockquote><p>Pauls had the KL31 cams and he had the millenia/MS8 curved neck IM.
Its not the hood that rubs, the straight neck hits the battery/master cylinder. I will work on those mx's though that are right hand drive.
- Custommx3
OK,
Thanks<hr></blockquote><p>The heads I believe say KL131 (could have something after it but it says that) on a true KLZE. You can look between the intake runners to see the casting numbers. Someone verify that number please.<p>[ January 30, 2003: Message edited by: Custommx3 ]</p>
OK,
Mine had kl-01 cams with a white dot car is still quick my engine was a 97 so they may have changed. I don't believe all kl-01 cams are the same. I think Coleman has the same cams as I do.
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Custommx3:
Its not the hood that rubs, the straight neck hits the battery/master cylinder. I will work on those mx's though that are right hand drive.<hr></blockquote><p>
This came out of an automatic they have said. does that sound right? Also do you know if a J-spec Klze ECU for an automatic will work for a maunal trans?
Thanks
Thanks
I hadn't realised the straight neck is ok on RH Drive; that's good news. Do you need to use the MX-6/Probe flexible tube to connect to the VAF?
