shifter bearings?
Posted: January 25th, 2003, 6:53 am
by reSa
forgot something! how much does it cost to fix my shifter? had the SAME exact problem on my RS... the shifter wiggles like crazy...like its in neutral in every single gear. i think my friend told me its just shifter bearings. has anyone else had this iRking problem?? how much did it cost to fix?
Re: shifter bearings?
Posted: January 27th, 2003, 10:33 pm
by lstpier
You can try to torque the bolt connecting the shifter to the shift rod (and bolt between the shifter rod and shif actuator of the tranny). If it doesn't help your shifter bushings are probably worn. Change them for Mazda ones or get stiffer aftermarket ones.
Posted: January 27th, 2003, 11:58 pm
by eunosads
it's your shifter bushings for sure (rather than bearings, there are no shifter bearings AFAIK).. I recommend the Bronzoil bushings available from [url=
http://www.srdperformance.com,]
www.srdperformance.com,[/url] these are great and will make your shift so much more precise.. they will last ages too.. otherwise you can get the OEM shifter bushings.. these will make your shift feel better and less sloppy than it currently is, but won't last as long as bronzoil ones.. <p>@ds
Posted: January 29th, 2003, 5:34 pm
by reSa
thanks guys
) and yeah i realized after i had posted that i made a mistake...bushings not bearings...for some reason i couldnt think of the word and bearings sounded just right at the moment.
) thanks for the advice!
