Battery
Posted: January 14th, 2003, 11:20 pm
by JJ
is it normal for the lights to dim a lil when i press down on the brakes or when i put my window up or down???
is my battery gettin low on power?
Re: Battery
Posted: January 14th, 2003, 11:25 pm
by mzdspd
no its normal
Re: Battery
Posted: January 14th, 2003, 11:29 pm
by JJ
LoLz its a lil wierd to be normal but wuteva...
ight thanx
pEace
Re: Battery
Posted: January 15th, 2003, 2:02 am
by pelado
No, that ain't normal. Battery must be getting weak, go to a parts store and get it tested.
Re: Battery
Posted: January 15th, 2003, 4:41 pm
by IanL
It could also be a poor earth connection between battery and chassis (high resistance causes volt drop; the more current drawn, the bigger the drop, the dimmer the lights, etc). Just clean it up and grease with vaseline or similar.<p>If it happens when the revs are high, it also suggests the alternator output could be below par.
Re: Battery
Posted: January 15th, 2003, 5:30 pm
by babyblue
It may not be your battery at all It could be the altnator as well.
Re: Battery
Posted: January 15th, 2003, 7:50 pm
by JJ
guess ill go get the battery tested and just work from there.
Car starts up fine just wonderin why it wuz doin that.
thanx yaLL,
pEace
Re: Battery
Posted: January 15th, 2003, 9:12 pm
by mzdspd
my rs and gs both do it. and my gs has a 220A alt and a new batt and 1/0g grounds so its def normal. it has to do with ur vacume do a search its been asked and argued before
Re: Battery
Posted: January 15th, 2003, 10:47 pm
by pelado
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by mzdspd:
my rs and gs both do it. and my gs has a 220A alt and a new batt and 1/0g grounds so its def normal. it has to do with ur vacume do a search its been asked and argued before<hr></blockquote><p>Since when does putting the window up or down got a damn thing to do with vacuum?
Re: Battery
Posted: January 15th, 2003, 10:59 pm
by mzdspd
i meant about the brakes not the window
Re: Battery
Posted: January 16th, 2003, 12:14 am
by treckrtj
my grandfather and father run a lead-acid battery store. specialize in auto batteries and ignition electronics. Obviously I have grown up around there and work there. Here's the deal. Alternator. It COULD be the ground like suggested a few replies earlier, but I have never seen that happen. But it is still feasible. Any battery store or garage (not auto parts store) will test your battery AND your alternator! So do that. But I would bet my favorite coffee mug it's the alternator. I've just seen it too much NOT to think so.........
