Driveshaft Tool
SimonPK
Driveshaft Tool
Post by SimonPK »
What's the best home made tool to use for holding in the gears when the driveshaft is pulled out? I would appreciate a diamater and length measurement so I can make something up. Also when the shaft is pulled out how quickly do you need to get the tool in?<p>If anyone has any points on what can wrong I would like that as well as normally I seem to have those sort of things happen to me!<p>thx
lazzyie
Re: Driveshaft Tool
Post by lazzyie »
If you are talking about the spidergears in the tranny just shove some newspaper or a towel in it.
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi :)
SimonPK
Re: Driveshaft Tool
Post by SimonPK »
you make it sound so simple.....<p>thanks!
pelado
Re: Driveshaft Tool
Post by pelado »
shop rags
