'93 GS engine and miata 1.8L engine the same?
hello,<BR>I am looking at performance parts at <A HREF="http://www.obxracingsports.com" TARGET=_blank>www.obxracingsports.com</A> and they sell a bunch of stuff for the 1.8L miata, is that the K8 engine, or no?
PaAutoRacing.com's MX-3000GT
- Custommx3
- Site Administrator
Re: '93 GS engine and miata 1.8L engine the same?
the miata is a 4cl engine, similar to the 4 cylinder, the k8 is a v6.
Hey MX-3000GT,<P>Nope, about the only thing you can transfer from the Miata B series is the lifters and shims from the 93-97 engine. I've been trying to hunt some down
thanx, wasnt sure if the miata has a 6 or not...damn that woulda worked out nicely
You can swap a miata engine in, like 93+ models are nice for mods. The 98+ are real sweet for turbos. Just need to get the tranny, ecu, mounts, etc.<P>Sucks pricewise
If your gonna be swapping engines that dont swap or bolt right in.... you might as well save your cash for another 3-4 months and buy a mitsubishi evo5 / 6 engine.<P>rated at 206kw (280ps) stock<BR>runs boost at around 14lb<BR>and is a inline 4.<P>if you hook this up into your car you should be pulling 13sec 1/4 miles
In
Eunos 30x, v6
KL-ZE, 2.5in exhaust, K&N intake
Unichip, LSD, 13lb flywheel, ACT2 clutch, NGK iridium Plugs, Top Gun Leads...<p>Goin In
Cams, Headers, TB, Extractors,
Bored to 2.8, Mazdaspeed Struts, Mazdaspeed strut tops,
Mazdaspeed swaybars, Eibach springs, Cusco Adj. Strut tops, Body kit, Altezza lights, Short shifter, Crossdrilled rotors and Calipers from AP racing, Braided brake lines, Braided clutch line, Mazdaspeed steering wheel, Mazdaspeed Leather shift knob,
Eunos 30x, v6
