OBD1 / OBD 2
Posted: November 13th, 2002, 5:28 pm
by DeanoGS
were all mx-3 ecu's OBD-2?<BR>or were the ones from 92-94 obd1 and 95 and 96 obd2?<P>thanks <P>dean.zarrillo@mts.net
Re: OBD1 / OBD 2
Posted: November 13th, 2002, 5:38 pm
by mazda20
They started OBDII around the end of 94, but I don't think the standard went into effect until 95 so your pretty much right.
Re: OBD1 / OBD 2
Posted: November 13th, 2002, 5:45 pm
by DeanoGS
So i have a 96 GS, is it OBD-2?<BR>I need to know b/c i need a new ECU, and as far as i know you cant mix and match right?<P>dean.zarrillo@mts.net
Re: OBD1 / OBD 2
Posted: November 13th, 2002, 11:11 pm
by pelado
yes<BR>yes
Re: OBD1 / OBD 2
Posted: November 14th, 2002, 8:04 am
by dylanmx3
What would be the difference between the two...other than the fact that one is an OBD1 and the other is OBD2. Same power train, sensor etc...presumably near identical mapping. Just curious because I've been doing some research on OBD2 laptop software for doing live diagnostics. I've a pre-OBD 2 94GS and I was considering a swap.<P>Dylan
