Idling funny, almost stalling
Andrew_Pakula
Post by Andrew_Pakula »
My car has ben idiling kind of funny the last week or so.<P>While idliling it feels and sounds like some times its almost going to stall but doesn't.<P>Maybe I need to get a tune-up done.
David Coleman
Re: Idling funny, almost stalling
Post by David Coleman »
I'd check the plug wires, plugs, and intake boot for vacuum leaks.
David Coleman
marshmallow15
Post by marshmallow15 »
a friend of mine had the same problem on his 240sx and it was because of a dirty and leaking fuel injector....when idling is black smoke coming out of the muffler? if so it might be that.
- team slideways
Andrew_Pakula
Not entirely sure, i'll have to check.<P>I am going to get a tune-up done on Monday probably though, it's long over-due.
marksoden
Post by marksoden »
For me, my stalling was a result of that most common problem of a crack in that accordian intake tubing...
94 Black MX3 GS Manual
Andrew_Pakula
Ok the car is actually stalling now at Idle.<P>However it only stalls if I push the break too much at idle.<P>I am going to bring the car in for a tune-up on Monday anyways so they can take a look at it.
pelado
Post by pelado »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Andrew_Pakula:<BR><STRONG>Ok the car is actually stalling now at Idle.<P>However it only stalls if I push the break too much at idle.<P>I am going to bring the car in for a tune-up on Monday anyways so they can take a look at it.</STRONG><HR></BLOCKQUOTE><P>I would look for a "break" in the vacuum tubing to your "brake" booster, or in the booster itself.
Shades
Post by Shades »
For me it was one of a combination of the vacuum hoses, dirty battery terminals, and bad ground wires. One of those fixed my problem, cause I had the same thing happen...
"Do it ONCE, do it RIGHT!"
Andrew_Pakula
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by pelado:<BR><STRONG><P>I would look for a "break" in the vacuum tubing to your "brake" booster, or in the booster itself.</STRONG><HR></BLOCKQUOTE><P>That sounds like it might be it but I am not entirely sure so I will get it check out tomorrow among a few other things that need some maintenance.
