Interior wiring
Posted: October 23rd, 2002, 9:54 am
by Tyler17rose
Hi, i just got my car about a month ago and the power windows dont work, and the passenger side speakers dont work. But the thing is, if i replace the fuse in my power windows, they will work for about 30 seconds then blowthe fuse again. So what i was thinking and need some help with is, maybe the speakers are somehow causeing to much current to run threw the circuit and are blowing my window fuse? could this be? and if not what do i need to do to fix this problem. If this isnt a normal problem i'm dredding taking things apart and checking voltage of each wire, one at a time till i find the problem.... so if anyone can help me, plz reply..... Thanks
Re: Interior wiring
Posted: October 23rd, 2002, 10:18 am
by Cacho
You have to check your wires on your passenger door to see if you shorted out any wires. Did you recently add any speakers stereo or something you might have changed?
Re: Interior wiring
Posted: October 27th, 2002, 11:15 pm
by Tyler17rose
No i havnt added new speakers or anything yet. I havnt had time to take things apart yet, but when i had my car in to get the timing belt and stuff done the mechanic told me that the insulation around a couple wires have worn and exposed the bare wire to each other. This apparently is happening right where the wires go into the door (the rubber thingy) so as soon as its not raining and i have time i'm gona check that out! if thats not the problem, more suggestions would be nice! thanks again!
