KL46 ECU?
Re: KL46 ECU?
Don't know but visit this thread......the search string was tough "klze ecu" <BR> <A HREF="http://www.mx-3.com/cgi-bin/ultimatebb. ... 5&t=001616" TARGET=_blank>http://www.mx-3.com/cgi-bin/ultimatebb. ... =001616</A>
Re: KL46 ECU?
kl46 is an ecu for a North American 2.5 liter, might have stalled because the knock sensors are different [img]shrug.gif"%20border="0[/img]
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
Re: KL46 ECU?
Do you mean it is for the Probe's KL03?
Re: KL46 ECU?
if you have a 1.8vaf with that ecu then it will stall but if you put a 2.5vaf it will run<BR>the kl-ze ecu is kl31 and kl36 big<BR>also another way take it up to 180 and if it does not cut out then it is not a kl-ze
Re: KL46 ECU?
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by v6nut:<BR><STRONG>Do you mean it is for the Probe's KL03?</STRONG><HR></BLOCKQUOTE><P>yes
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
Re: KL46 ECU?
I am currently using 2.0 VAF (JE50) which is also similar to 1.8VAF. Can I just replace the EPROM on the KL46 ECU with KL36 EPROM? Will this solve the VAF incompatibility problem?<P>TIA.
Re: KL46 ECU?
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by v6nut:<BR><STRONG>I am currently using 2.0 VAF (JE50) which is also similar to 1.8VAF. Can I just replace the EPROM on the KL46 ECU with KL36 EPROM? Will this solve the VAF incompatibility problem?</STRONG><HR></BLOCKQUOTE><P>yes
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
