Ok, here's the story. I have a MX-3 GS. It used to be a 1.8 V6 with an automatic slushbox attached to it. I wanted some real power so back in march of this year I swapped in a KL-ZE and converted the car to a stick at the same time. While I had the motor out I installed an ACT stage II Clutch kit (model #<A HREF="
http://www.advancedclutch.com/v3/appsfr ... asp?ID=512" TARGET=_blank>Z62-HDSS</A>) to handle the additional power and torque. Ever since the day I installed the motor, tranny and clutch I have had NO problems with the ACT clutch,...until now. I was coming home from work yesterday and I had a little open space so I decided to put the beast KL-ZE to work. I hit it and kept it at WOT in first gear up to 7000 tires chirping from 4000 on up in all it's glory and I’m having a blast!
Then I go to grab second gear real quick and as soon as I hit the gas again after the shift I watch the RPM slip from about 5500 down to about 3900 and that's when the clutch finally hooked up.
I am happy again. I tried about 4 good "spirited" shifts and success everytime. So I slept good last night not knowing why that fixed it, but not questioning it either. Today, I drove to work, and back again. Both ways I drove like a little old lady in light of what happened the day before. When I was almost home I decided to make sure the clutch was still holding and opened her up again. I take off and on the 1->2 and the 2->3 shift it SLIPS!!!
My knowlegde is a little bit lacking on this, but I sure want to fix it. If you managed to read all this I have respect for you and I thank you for your time, I just hope someone can help me figure it out.
<p>[ September 25, 2002: Message edited by: 93 mx-3 gs/se ]
