head swap possible?
head swap possible?
is it possible to put a set of heads off a kl-ze or kl-de on a kl-08, i know its possible, but will it run that is my real question. the cams can be swaped so why not the whole heads?
Re: head swap possible?
That is an excellent question, much better than those stinkin' muffler questions.<P>Hopefully David will reply. <P>I'm not certain of the answer but I believe the valves are spaced too far apart for the bore size (i.e., valves can contact cylinder bore).
on the subject of the ze hey pelado can u shoot me a PM with ur email addy so i can ask you a few questions about your swap...thanks<P>AJ
resurected KL-ZE,ZE ECU, 9lb Fidanza Flywheel, CMIII, home depot CAI, Hiflow Cat, 2 1/2" piping, exhaust, 2 MASS 2012's, Cadence A7, Blaupunkt Casablanca, and a no damn CEL light!!!
Pelado is right: the valves are too far apart for a 75mm bore. Also, the combustion chamber is bigger than a K8 head, so you'd lose effective compression. Might make an interesting turbo setup if you bored it over to ~85mm.
David Coleman
