ok yall what do u know
hey what do u know about the jet stream permace chip on the site it says 15-20 hp does it really work if not what does
Re: ok yall what do u know
From what I know the chips that are sold like that are for the stock configuration. If you have done mods I'd get the ECU reprogrammed by someone who knows what they are doing
vemon and jet are crap! a chip on your tps will not give you that much horsepower! a bored throttle body will give you like 10hp and that is backed by mechanical fact.
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
