high flow cat
- Buff1110
high flow cat
i wanna add a high flow cat onto my car but need the dimensions and inlet/outlet sizws. right now i have a 2.25" cat back exhaust so i really only need dimensions of our cat or one what will fit.<BR>thanks<BR>Dan
Dan
02 Tacoma TRD - Daily
Re: high flow cat
wouldnt u wanna keep it stock .. alot of people are forgeting thats its a import.. theres gotta be enough back pressure if u do change it keep me posted with results.. going with short headers from hurrican an stock converter with 2 1/2 cat back sounds an performes nice
92GS.KLze 2.5 ,CT26 TURBO,40K MILES,Ram air intake,2.5 cat back,coming.pullys,cams,Pistons,
valves & springs,venom injectors.
- Buff1110
Re: high flow cat
basically all the mods im doing is in preparation for my ze inplant in early summer so i wanna get as much power out of it possible. are there any brands with part numbers anyone is using and is successful<BR>?<BR>Dan
Dan
Re: high flow cat
Billy, if you would read the v6 faq, then you would see that engines need no backpressure, it is exhaust velocity that is needed, a larger diameter pipe allows more volume of gas to exit, but lowers the exhaust velocity.
