ok i got problem
ok i got problem
i want intake its either prm or k&n intake which is better and why thanks
Re: ok i got problem
I would say PRM as the K&N is just a new filter, it says it adds hp but it doesn't really offer alot. PRM is famed to be really good but I don't know so much about theirs
PRM or just make your own.
I beleive it is bad to have a heat conductive metal intake pipe because it will transmit the engine bay heat to the intake air.<P>also are there any dynos on stock with k+n vs. prm or home made becuase the banana tube may give torque. [img]shrug.gif"%20border="0[/img]
13.023 @ 105 mph
So what do you propose that people use?<P> <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by aaron the hic:<BR><STRONG>I beleive it is bad to have a heat conductive metal intake pipe because it will transmit the engine bay heat to the intake air.<P>also are there any dynos on stock with k+n vs. prm or home made becuase the banana tube may give torque. [img]shrug.gif"%20border="0[/img]</STRONG><HR></BLOCKQUOTE><p>[ September 04, 2002: Message edited by: LiQuId ]
- mitmaks
u can install one from civic like i did, cheaper and still gets cold air in.
