Engine is revving?
Absath
Engine is revving?
Post by Absath »
I just got home from work. Its late, and my empty light came on. There are no gas stations open, so its gotta wait till morning.<p>but on the way home, the engine start revving itself, even at idle, it was reving between 2 and 3 rpms.<p>is this related to the fact that i'm about to run out of gas, or do i suddenly have an entirely different problem altogether?<p>-Abs
Don't park drunk, accidents cause people.
92 Blaze Red MX-3 GS, KL-ZE, ACT Clutch, KL 36 ECU, SS Clutch Line
Absath
Re: Engine is revving?
Post by Absath »
ok the tank is full of gas, and even when the clutch is disengaged, the engine still revs between 2.5 and 3 rpms.<p>any ideas on what the problem could be?<p>-Abs
airjordon_09
Post by airjordon_09 »
the only thing i can think of bro is your tranny, i had the same prob and it ended up being the tranny, i could be wrong though.<p>
peace
JºrDôñ
Mx sold, gonna miss ya babe
E-MAIL
gti_driven@hotmail.com
Absath
Post by Absath »
i was talking to a friend, and he seemed to think it was the wiring. a loose connection, bad sensor or somesuch.<p>how could it be the transmission? i have no problem shifting gears... the rpm's are reving... thats the engine, not the tranny.<p>-Abs
novadoc
Post by novadoc »
do a search<p>topic has been brought it many times, and it seems that there is a lot of things that could cause it<p>try adjusting your TPS
check for cracks in your intake hose
any vacume leaks
NoVa<p>Image
GQSmoov28
Post by GQSmoov28 »
I thought this was normal for the V6, or at least I thought I read that somewhere. My 92 GS does it all the time when the weather is cold and I drive it before it fully warms up!
92 Mazda MX-3 GS
My Ride http://members.cardomain.com/gqsmoov28
Mods So far:<p>16" Motegi MR7 (White)
Dunlop SP Sport FM901 Tires
Xenon Hiper White Bulbs
MazdaSpeed Shoulder Harness Pads
Type R style Indiglo Shifter
DopeyD
Post by DopeyD »
I had a similar problem that started for no apparent reason
Mine was the water pump check it out if not I dont know. Good luck
Absath
Post by Absath »
the day after i posted this, my car started overheating, and my check engine light came on.<p>i filled up my coolant, and the engine hasn't revved out of turn since.<p>-Abs
