v6 Brake Master Cylinder?
Posted: August 19th, 2002, 9:57 pm
by Mradio
Anyone ever changed master cylinder on a mx3?<BR>mine is leaking a little bit, right where the reservoir attaches to the cylinder, so iam thinking to replace both of them. <BR>Anyone knows anyplace where I can get them, besides the dealer for less than $200?
Re: v6 Brake Master Cylinder?
Posted: August 20th, 2002, 9:25 am
by andy
I have not replaced the master cylinder on the mazda yet, but the leak you talk of sounds like a cheap o-ring replacement. I would try replacing the o-ring first. If the <BR>mazda's resivoir is like most it should seperate from the cylinder, revealing the o-rings that seal it. If you can find the o-ring, you would save a lot.<BR>Andy P. 93 GS
