which ze ecu???
ghandi1981
which ze ecu???
Post by ghandi1981 »
the kl36 or kl31???<P>aj
resurected KL-ZE,ZE ECU, 9lb Fidanza Flywheel, CMIII, home depot CAI, Hiflow Cat, 2 1/2" piping, exhaust, 2 MASS 2012's, Cadence A7, Blaupunkt Casablanca, and a no damn CEL light!!!
lazzyie
Re: which ze ecu???
Post by lazzyie »
kl31 is a manual only ecu i believe, dave will probably know though
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi :)
phyzy
Re: which ze ecu???
Post by phyzy »
While we're on this topic, where exactly is the ECU located, because I tried looking for it, but I couldn't find it, and is an ECM the same thing as an ECU?
Custommx3
Site Administrator
Re: which ze ecu???
Post by Custommx3 »
its behind the ash tray under the dash
lazzyie
Re: which ze ecu???
Post by lazzyie »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by phyzy:<BR><STRONG>While we're on this topic, where exactly is the ECU located, because I tried looking for it, but I couldn't find it, and is an ECM the same thing as an ECU?</STRONG><HR></BLOCKQUOTE><P>i think it is pcm for new cars
96 Integra LS DD
91 Crx Si drag car
nicolasbeique
Re: which ze ecu???
Post by nicolasbeique »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by ghandi1981:<BR><STRONG>the kl36 or kl31???<P>aj</STRONG><HR></BLOCKQUOTE><P>Isn't it one has better low end torque and one has better top end?<P>Would the top end one be better for performace rignt?
<A HREF="http://www.spheregraphics.com/" TARGET=_blank>Image</A>
ghandi1981
Re: which ze ecu???
so whats the diff b/ the 2???<P>aj
ghandi1981
Re: which ze ecu???
also...do ecus go out??? i found one that i want to get but the guy wont reply to my questions..<P>aj
killerpickle
Re: which ze ecu???
Post by killerpickle »
I think most klze'ers use their regular K8 ecu (not sure of the exact tech. name) such as dave, and some use the 2.5 ecu from an mx-6 or so, and a few have reprogrammed ones, such as the one corksport sells for 400 bucks that is programmed for the klze. <P>I think the main difference, is the VRIS points. They are not set properly to really enhance the power curve as much as a programmed one. I remember seeing a dyno graph of the k8 ecu on a 2.5 that had pretty weird dips and blips...not really smooth...anyway this is all that I remember
Tom Alexander
David Coleman
Re: which ze ecu???
Post by David Coleman »
IIRC the KL31 ecu is from a manual MX-6, and the KL36 is from an automatic MX-6/Millenia. Both will work on a manual car, but only the slushbox ecu will work on a slushbox car. I haven't researched it all that much, cause all stock ECU's blow, cause you can't chip them effectively, so I'm just going stand alone. <P>Oh yeah, I'm running all K8 electronics at the moment. [img]shrug.gif"%20border="0[/img]
David Coleman
nicolasbeique
Re: which ze ecu???
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by David Coleman:<BR><STRONG>...cause all stock ECU's blow, cause you can't chip them effectively, so I'm just going stand alone. </STRONG><HR></BLOCKQUOTE><P>Stand alone you mean where you plug it in your laptop??? Would appreciate some clarity on this subject. Everyone seems to say stand alone is better but I'm still not quite sure what it is? Who makes stand alone ecu stuff for the mx-3 with a KL-ZE???
David Coleman
Re: which ze ecu???
I have a piece about it on my KL page on my site with links. The new AEM unit looks the best. <BR> <A HREF="http://plaza.ufl.edu/mugen23/KL.htm" TARGET=_blank>http://plaza.ufl.edu/mugen23/KL.htm</A>
David Coleman
nicolasbeique
Re: which ze ecu???
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by David Coleman:<BR><STRONG>I have a piece about it on my KL page on my site with links. The new AEM unit looks the best. <BR> <A HREF="http://plaza.ufl.edu/mugen23/KL.htm" TARGET=_blank>http://plaza.ufl.edu/mugen23/KL.htm</A> ... ><P>Thanks for the info<P>but $1,950.00usd for the AEM one!!!!! How much do the other ones run at?<P>Seems REALLY EXPENSIVE! you can by 2 insain PC machines for that price!!! :p <P>seems kinda ridiculus...
pelado
Re: which ze ecu???
Post by pelado »
David, maybe I'm blind but I didn't see any links to the AEM unit on your page. Google helped though ;) <P>Nic, I found the AEM "plug and play" unit for an RX-7 for $1350 here <A HREF="http://coximport.com/Merchant2/merchant ... de=30-1800" TARGET=_blank>http://coximport.com/Merchant2/merchant ... 30-1800</A> <BR>However, I have a lot of doubts about the compatibility of an RX-7 harness with an MX-3 harness. I didn't see any AEM units listed for a MX-3, 626, MX-6, or Probe GT. There was another listed for a Miata but the image didn't come up.<P>I couldn't find a website for "insain", could you provide one for the curious?
VizualXTC
Re: which ze ecu???
Post by VizualXTC »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by pelado:<BR><STRONG> I didn't see any AEM units listed for a MX-3, 626, MX-6, or Probe GT. There was another listed for a Miata but the image didn't come up.?</STRONG><HR></BLOCKQUOTE><P>Yea I looked last time and found the same thing. I was wondering if we called them, they could possibly either fabricate something to work, or maybe produce something.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
