Is it bad to *switch* over to synthetic oil?
Posted: July 11th, 2002, 11:39 pm
by zytariuk
My car is at 127,000km and it's always had 10w 30 in it from the start. Is it bad for the engine if i was to put 5w 30 synthetic oil in from now on? Thanks
Re: Is it bad to *switch* over to synthetic oil?
Posted: July 11th, 2002, 11:40 pm
by OsoSlo z28
no
Posted: July 11th, 2002, 11:57 pm
by VizualXTC
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by zytariuk:<BR><STRONG>My car is at 127,000km and it's always had 10w 30 in it from the start. Is it bad for the engine if i was to put 5w 30 synthetic oil in from now on? Thanks</STRONG><HR></BLOCKQUOTE><P>Just make sure you don't mix the synthetic with the other. I've heard bad things about that. I dunno tho. But I'd wait until you change the oil before putting synthetics in.
Posted: July 12th, 2002, 1:44 am
by Buff1110
one thing to make sure though is that if ur car has high mileage bc synthetic is thinner and can leak out the gaskets a lot more than regular oil.<BR>Dan
Posted: July 12th, 2002, 6:45 am
by millionflame
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Buff1110:<BR><STRONG>one thing to make sure though is that if ur car has high mileage bc synthetic is thinner and can leak out the gaskets a lot more than regular oil.<BR>Dan</STRONG><HR></BLOCKQUOTE><P>Wow, thanks for mentioning that because that is EXACTRLY what is happening to me right now. I am at 220,000 kms, and using synthetic oil, and I was going to look for an oil leak and stuff, but I guess that's what it is.<P>Should I use a "normal" motor oil then, or just fix the gasgets???<P>Thanks, Aiden.
Posted: July 13th, 2002, 12:07 am
by Hy300
I'd replace the gaskets AND run the real oil.
Posted: July 14th, 2002, 5:01 pm
by Stevech_2001
ya and remember to use an engine flush because synthetics have more detergents and the extra crud that it breaks lose will be floating in your oil and can clog things.....hey man with high milage try useing that max life s--- it's suppose to "condition used seals"
Posted: July 15th, 2002, 1:44 am
by Buff1110
go back to regular oil, i personally have great luck with castrol gtx 5w-30 over the others i have tried (penzoil, quaker state).. and it would be a good idea to replace the gaskets as well<BR>Dan
Posted: July 17th, 2002, 11:25 pm
by Mradio
what Gaskets are you talking about?
