coolant reservoir relocation question
Posted: July 4th, 2002, 11:52 pm
by Falstaff
does the coolont bottle have to be the same height in relation to the radiator? i moved the bottle and positioned it lower than its original location and i was wondering if that would affect it at all or if there was any relation to the coolant level in the resevoir and its position (height) in relation to the rad.<P>thx.
Re: coolant reservoir relocation question
Posted: July 5th, 2002, 5:54 pm
by pelado
Since the coolant system is pressurized, no it doesn't matter. The tank is only used to relief fluid to it when the pressure setpoint in the radiator cap is reached and to allow the vacuum in the system to draw fluid from the tank when fluid gets low.
Posted: July 5th, 2002, 6:14 pm
by Falstaff
that's what i thought.. but i wanted to be sure :) thanks pelado
Posted: July 6th, 2002, 12:16 am
by white fish
Why did you relocate the bottle?<BR>just curious ;)
Posted: July 6th, 2002, 12:58 am
by MAZDASPEED STEVE
probably to mount a perfect ram air system? the coolant resevoir takes up too much space. [img]shrug.gif"%20border="0[/img]
Posted: July 6th, 2002, 9:02 pm
by Quazi5
I thought the same thing as MS Steve. My question is where can I get a Rad. cap that allows coolant flow both ways but maintains pressure in the system. Also, where did you relocate it to? My first thought is in the fender well but that's just a guess. Later :)
Posted: July 6th, 2002, 11:57 pm
by pelado
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Quazi5:<BR><STRONG>I thought the same thing as MS Steve. My question is where can I get a Rad. cap that allows coolant flow both ways but maintains pressure in the system. Also, where did you relocate it to? My first thought is in the fender well but that's just a guess. Later :)</STRONG><HR></BLOCKQUOTE><P>Your stock radiator cap does that.<P>I relocated mine next to the driver's fender, there really wasn't any place else to put it.
Posted: July 7th, 2002, 3:58 am
by Falstaff
survey says.....<P>cold ram air intake <P>*bing*!
Posted: July 7th, 2002, 11:16 am
by MAZDASPEED STEVE
You don't need to relocate it, u should be able to fit your air filter down there, trust me I fit my 6X9 K&N filter down there. :D
