Lucas Oil Treatment???
macnwigs
Post by macnwigs »
Is this stuff any good? I've heard about it and the following Miata guy says it'll fix the HLA problem...Anybody here use it? or reccomend it?Glenn Toth<BR>1995 Mazda Miata MX-5<BR>This is what the Miata guy said:<BR>"I recently purchased a 1995 Mazda Miata MX-5 Miata sports coupe. After the purchase I noticed loud hydraulic lifter noise on start up and after a highway run. Logging onto the Miata.net bulletin board I found that this Lifter noise is very common to Miatas. A combination of oil filter and oil viscosities is supposed to help the problem.<BR>I tried everything I could to eliminate the noise: Oil weights, expensive filters, additives, etc. NONE WORKED! I then tried your Oil Stabilizer. I added a pint to four quarts of oil. I now have no more lifter noise- ever! Not on start-up or after a hard drive.<P>Thank you for a great product! I am going to tell all the other Miata owners how your product saved my engine and ended months of frustrating lifter noise.<P>Glenn Toth"
"A man is only as old as the woman he feels"
Groucho Marx (1895-1977)
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former."
-Albert Einstein
macnwigs
Re: Lucas Oil Treatment???
Post by macnwigs »
bump
-Albert Einstein
MAZDASPEED STEVE
Post by MAZDASPEED STEVE »
I use it religously! It eliminates all those annoying knocks and pings. I used it on my old 1.8L V6 and I am even using it now when I'm breaking in a rebuilt 2.5L.<BR>Add it everytime you change your oil, works great. :)
THANX
MAZDASPEED
STEVE
macnwigs
Post by macnwigs »
so do I just ask the guy doing my oil change to put some in? Or can I add it now - I had an oil change about 1000 km's ago?
-Albert Einstein
platinum MX
Post by platinum MX »
i work at a car dealership and we put that stuff in ALOT of cars.....works GREAT...
Dave<BR>93 Mx-3 GS SE *under construction*<BR>95 Prelude *3rd place at Carlisle Custom Compact Nationals 2002 92+ Prelude Wild class*
