Stock GS wheel weight?
Anybody know the weight of the stock 15 inch rims without tires? Thanks!
Re: Stock GS wheel weight?
About 2.5 henways.
duh? wots a henway? uhuh...
6 or 7 pounds (*sigh*)
theres no way the stock rim can way 7 lbs does anyone know the real weight?
It would probably help if you said which style GS wheels you are talking about.
Shaun Newman
- jpwmx3
He did say! it's in his info section.<p>[ April 04, 2003: Message edited by: jpwmx3 ]</p>
1993 GS V6/402,000km http://images.cardomain.com/member_imag ... 290_18.jpg
I find it hard to believe its 17 pounds. They dont even feel that heavy with tires on them. Someone should test.
My Cardomain site
My Cardomain site
92 gs rims are 14 lbs weighed them awhile ago.
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
crap I thought they were over 20, because when I bought rims I took in to concideration dropping the weight from my stock rim setup. O well I guess I added a few pounds... thats kinda dissapointing, its tuff to find a rim that's less than 14 pounds and looks good.
1993 Mazda mx-3 GS - Blaze Red (Totaled) Went through an 89 rx7 and a 93 del sol. Now searching again!
http://www.cardomain.com/id/mxmisl
Volk TE-37s
'94 Blaze Red RS<P>I may not have a lot of horsepower but I know how to use it!
mazda has always used light aluminium wheels, they get very good wheel companies to make them. They usually try to make the wheel lighter every coupple of years, the miata has had 3 rims that look exactly the same but each are different weights.
Yes, I AM a bastard
Yes, I AM a bastard
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by jpwmx3:
He did say! it's in his info section.<p>[ April 04, 2003: Message edited by: jpwmx3 ]<hr></blockquote><p>Where does it say which year mx-3 he's referring to? There is a difference between the GS wheels if you didnt know.
Shaun Newman
- jpwmx3
At the bottom of his post where it says CAR:....like yours and mine and everyone elses.
And I know mx-3's since 1992 when I bought mine. :p
