156.2 H.P. KL-ZE Dyno Run
curtklze
Post by curtklze »
I jsut took my '95 GS KL-ZE to the dyno and it made 156.2 H.P. at 6000 rpms and 147.7 LBS<BR>of torque at 4700 rpms.<P>Both drop of after 6300.<P>My car is running the stock exhaust manifolds<BR>and muffler, stock intake pipes with the air filter removed(dyno only).<BR>And a cork sport KL-ZE programmed 1.8 ecu.<P>Dose this sound right? Will my car pick up about 18 whp(21 BHP) with a cold air intake and a 2.5 inch exhaust with high flow muffler?<P>Any one have a ZE that is simmilar to this?
Yes, I AM a bastard
David Coleman
Re: 156.2 H.P. KL-ZE Dyno Run
Post by David Coleman »
Those numbers are right on for your setup. A 2.5" exhaust will help it breathe alot, as well as a cold air intake.
David Coleman
mitmaks
Post by mitmaks »
i thought that ze should have 200hp stock???? is there something wrong? how come u get around 160hp?
OsoSlo z28
Post by OsoSlo z28 »
the stock 200hp is to the crank. his numbers are to the wheels.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
Zoso124
Post by Zoso124 »
196hp at the crank not the wheels. As dave said you'll pick up a few with an exhaust but not 18-20 hp. Any idea what Corksport programmed on ur new ECU? or what they changed I guess you could say.
Mike Evans
Gone:
curtklze
Post by curtklze »
I told cork sport to optimize the ecu for a KL-ZE with cold air intake, high flow cat and a high flow exhaust.<P>I dont have any of that on right now but I will this summer. This might be why it is a little low on power.The computer might be giving the engine too much fuel and timing.<P>The other dyno graphs I have seen of KL-ZE probes show a noticable drop in power<BR>(10-20hp) at each of the VIRS cross overs(2700,3700ect) but mine is very straight with only about 1-3hp loss.
Yes, I AM a bastard
David Coleman
I havent seen any good dyno reports from the Corksport EPROM. They get it from EL prototypes, who I've never seen anything impressive from. There's a PT member by the name of Craig Spencer who is getting real ZE ECU's that will plug into our harnesses and use our JE50 VAF from New Zealand. Should be around $100USD shipped I believe.
David Coleman
lazzyie
Post by lazzyie »
They are out of the ecu part #kl31 its about $170 shipped/insured to USA with a 30 day warranty. Dah well... missed it by a day.
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi :)
nicolasbeique
Post by nicolasbeique »
Is it possible that its just a KL (KL-03)???? I still dunno where to get my KL-ZE and I'm scared that they would send me a KL-03 instead of the KL-ZE... is that possible???
<A HREF="http://www.spheregraphics.com/" TARGET=_blank>Image</A>
pelado
Post by pelado »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Nic Beique:<BR><STRONG>Is it possible that its just a KL (KL-03)???? I still dunno where to get my KL-ZE and I'm scared that they would send me a KL-03 instead of the KL-ZE... is that possible???</STRONG><HR></BLOCKQUOTE><P>Yes, it is possible, anything is possible. If you haven't searched out there and viewed the available photos of ZEs and read the threads on how to identify ZEs, then you're as careless a purchaser as you can possibly be. Don't ask me where they are either! If I can find them, YOU can find them! It's an easy search!
curtklze
Post by curtklze »
Im not making any excuses about the horse power my car made, But I just want to clear some things up.<P>I wanted to know how much power my car is making as I drive it every day.Not how much power I can get out of it by icing down the intake manifold and letting the engine cool down half an hour with huge cooling fans on it between pulls.<P>Those numbers I made were after I had made my first pull, which was made after a 15 min heat soak after I came off the highway.<P>Then we let the car cool off with the hood open and the engine off for 4 min while I pulled out the air filter.<P>If I wanted to make over 160 HP at the wheels Im sure I could have by doing what I typed above, But that is not how my car is every day. :)
Yes, I AM a bastard
timpronk
Post by timpronk »
here is a dyno chart for a klze in a probe <P>172 hp 160 ft lbs. <A HREF="http://plaza.ufl.edu/mugen23/KL.htm" TARGET=_blank>http://plaza.ufl.edu/mugen23/KL.htm</A>
92 MX-3 GS 2.5 KLZE
14.385 @ 98.21
pelado
Post by pelado »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by timpronk:<BR><STRONG>here is a dyno chart for a klze in a probe <P>172 hp 160 ft lbs. <A HREF="http://plaza.ufl.edu/mugen23/KL.htm" TARGET=_blank>http://plaza.ufl.edu/mugen23/KL.htm</A> ... Apparently Curt, your engine is in the same ballpark as another KLZE. <P>Now, if you really wanted some depressing numbers, dyno a 1.8 V-6! The best I've come across on a K8 is about 130 whp and that's with all the bells and whistles.<P>Are you running a 2.5 VAF with a Millenia intake?<BR>Can your dyno operator use your O2 sensors to give you some A/F numbers?<P>The only additional suggestions I'll make is to install phenolic spacers.
curtklze
Post by curtklze »
Thanks for the info :) <P>Im running the stock 1.8 VAF sensor and a re-programmed 1.8 ECU.<P>The eunos 800 manifold is allready touching the hood liner on my car if I were to use the spacers I would have to remove the liner and grind down some of the bolts on the intake manifold, and maybe grind the hood a little :D ) I will be done.<P>Then comes the 65 shot of ZEX :D
Yes, I AM a bastard
