lets talk some KL03
lets talk some KL03
ok guys got a couple quick questions... first what is meant by OBII in terms of probes and other 2.5L powered cars. second, were there any models which carryied a super/turbocharged engine. if not what are the best choices for aftermarket forced induction? finally has anyone recently done a website on their swap other than those first couple of guys on the links page... i need some fresh new info.
92 Mazda MX-3 GS: blaze red, bone stock, and daily driver
86 RX-7 GXL: '94 LT1 V8, 6 speed tranny, scary fast. SOLD
93 Mazda RX7 R1 LS1/6speed... 75% complete
http://www.cardomain.com/id/mattsterrx7" onclick="window.open(this.href);return false;
^link to my V8 swap page
Re: lets talk some KL03
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by mattster:<BR><STRONG>ok guys got a couple quick questions... first what is meant by OBII in terms of probes and other 2.5L powered cars. second, were there any models which carryied a super/turbocharged engine. if not what are the best choices for aftermarket forced induction? finally has anyone recently done a website on their swap other than those first couple of guys on the links page... i need some fresh new info.</STRONG><HR></BLOCKQUOTE><P>1) OBDII engine management systems require a scanner to read the malfunction codes, 96 or later.<BR>2) No turbo'd, super'd MX-3s. A Millenia S has a supercharger but it is a Miller cycle engine.<BR>3) See Forced Induction forum.
thanks man<P>so you cant use any KL03 made in 1996 or newer?
- MAZDASPEED STEVE
I think you can still use a 96 or newer 2.5L, but you will probably have to get the ecu to match.<BR>Jeff Abrams has a supercharged 2.5L, but his is totally custom- <A HREF="http://www.mazdamaniac.com" TARGET=_blank>www.mazdamaniac.com</A> ![Smile :)](./images/smilies/icon_smile.gif)
THANX
MAZDASPEED
STEVE
MAZDASPEED
STEVE
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by mattster:<BR><STRONG>thanks man<P>so you cant use any KL03 made in 1996 or newer?</STRONG><HR></BLOCKQUOTE><P>You can use any KL you want. Just match VAF to the (95 or earlier) ECM/PCM/ECU that you're using (1.8 with 1.8, 2.5 with 2.5, 1.8 with ZE). It's not the mechanical side that matters in this case, it's the electronic side.
