O2's gone bad!
O2's gone bad!
Checked my engine codes and sure enought, codes 16, 17 and 24 came up. I believe 17 and 24 are the O2's. 16 is the EGR System, but that's because I'm not utilizing the egr since I have the ZE. The description for 17 & 24 were "INVERSION ERROR".....what does that mean?<P>My question is where can I find replacement O2's for a reasonable price. The O2's on our MX-3's, from what I've found, seem to be extremely expensive (lucky us)....probably cause it's a 4-wire (self heated) O2. I've found prices ranging from $75-$350 each....do any of you know where I can get a couple of O2's for a good price?
Do it.......Do it.......<BR>Do it ti'll you're satisfied!
Re: O2's gone bad!
Check out Jeff's Supercharged MX-3 website. part #'s and prices are listed
Re: O2's gone bad!
<A HREF="http://www.nopi.com" TARGET=_blank>www.nopi.com</A>
