Stalling at 55+ mph?????
Posted: March 29th, 2002, 7:59 pm
by MattPPK007
I have a 93 GS with an automatic and recently i was going about 55 mph with the pedal almost to the floor and when the car shifted into 4th gear it stalled... I pulled over and the car wouldnt start for about a minute.. then it started up and ran fine all night.. the next day i had the mechanics where i work look at the car and we discovered that my tranmission was all messed up so i had a new tranny put in at a mazda dealership and i figured that the stalling was related to the tranny but since ive had the new tranny the car is still doing the same stalling out business.... I would greatly appreciated if someone could give me a clue as to what might be wrong with my car. Also the stalling does not feel like it is injector related.. it feels as if someone just turned the car off.. the rpm's just drop instantly.
Re: Stalling at 55+ mph?????
Posted: March 29th, 2002, 11:02 pm
by Travis83
Distributor maybe...dont really know man. sorry
Posted: March 29th, 2002, 11:22 pm
by Potatoes
Just outta curiousity... how much did it cost you to put in a new tranny?
Posted: March 30th, 2002, 1:02 am
by MattPPK007
The new transmission came out to about 2250 but i only paid 100 bucks for a deductable on my warrantee cause ive only had the car about a month and it was from a dealership.
Posted: March 30th, 2002, 6:32 pm
by mazdakjs
Now first thing is first I am far from a mechanic. and you'll probably get a reply saying that I am dumb. but just to see what everyone else says, could it be flooding? maybe the comp. or easier yet. the injectors. once you get up to speed the injectors could flood. although it is hard to flood a fuel injection motor. since it didnt start for a few minutes thats all I can see. when it does it again check the plugs to see if they are wet. if they are tell a trusted mech. hope I help. <BR>Kyle, Northern crappy Ontario
Posted: March 31st, 2002, 10:48 am
by Globotang
Hey! I have the same problem!<P>My car is a '92 GS, manual trans. <BR>My engine has the same problem. I brought it<BR>to my mechanic and he couldn't find what was wrong with it...He said it may be the distributor, and to bring the car back when it fails to start for good...<BR>
Can you believe this!<P>I'm gonna bring the car to my local Mazda<BR>dealer tomorrow...keep you posted.
Posted: March 31st, 2002, 5:49 pm
by MattPPK007
Hey globotang, yesterday my car finally failed to start for good! .. i was driving along going about 55-60 and it stalled as usual and i pulled over to start it up again which only takes a few seconds usually and it wouldnt start so i had to get it towed to my house.. right now its sitting in the driveway dead... im calling the mazda dealership tomorrow morning as well... hit me back if you find out whats wrong with yours. thanks
Posted: April 2nd, 2002, 2:03 am
by cashmoneyspeed
on the 1.8 Liter V6 models the EGR piping an the EGR valve tend to get blocked with carbon. If it gets to blocked, then at cruise i would feel a hesitation and a drop in acceleration. Does the check engine light come on after cruising at highway speeds?
Posted: April 2nd, 2002, 7:43 am
by Globotang
Yesterday morning they replaced the distributor ($570 CAN) and so far it's running smootly.<BR>No check engine light ever came on while the <BR>engine was running, cashmoneyspeed.<P> Hope this helps.
Posted: April 2nd, 2002, 8:03 pm
by MattPPK007
yeah my local mazda dealership replaced my distributor too and everything is cool now.. it was 400 US including labor.. thanks for your replys everyone.. later
Posted: April 2nd, 2002, 10:23 pm
by georgechicken
wish i would have read this earlier.. this is a typical problem with the mazda K series V6... the distributor, being bolted directly to the head, doesnt dissipate heat well, and in turn breaks down a part on the ignitor in the distributor.. and signs that its failing is high-rpm shut-off.. it'll do it a handful of times before giving out fully.. ive had this happen to myself and a few friends several times already..
Posted: April 2nd, 2002, 11:23 pm
by Travis83
Ha! What do ya know? I was right. Damn good guess.
Posted: April 3rd, 2002, 3:45 pm
by onyx_ZX3
i have tried 2 differant onesfrom napa and my hesitation doesnt go away...i think it maybe somthing esle though, with this final disty it just cuts back doesnt shut off...especially if i gun in 1st gear then shift to second it cuts back alittle then taskes off...could it be the tps? if i had a leak in my intake piping? anybody?
