Syncromesh
pelado
Re: Syncromesh
Post by pelado »
Change your transmission fluid to Redline and see if that helps.
David Coleman
Re: Syncromesh
Post by David Coleman »
Yeah, Redline MTL or 75w90 are both good fluids.
David Coleman
Bri94GS
Re: Syncromesh
Post by Bri94GS »
Dave, have you heard anything about the tranny fluid called SynchroShift? or something like that? I know it's real good tranny fluid for some cars, but havent heard it thrown around in the mx-3 world yet
~Bri - Morph860@aol.com
'94 MX-3 GS (FOR SALE!)
'04 Mazda 3s 5-door
zoom-zoom
T Biller
Re: Syncromesh
Post by T Biller »
Sorry about my change of identity, but I became "unregistered" for some odd reason, then I couldn't re-use my old name when reregistering. Anyway, what's the scoup with this Redline stuff, is that just a fliud that you think is generaly good, or is there something special about it that may help? i had heard of some car's gearboxes working better on engine oil, which is why I asked the question, but I didn't want to risk finishing of my box for good by running something too light.
white fish
Re: Syncromesh
Post by white fish »
Redline is synthetic oil I use it and its "stable" it feels the same if its freezing out side or boiling hot<P><BR>anyone using royal purple?
Bri94GS
Re: Syncromesh
Post by Bri94GS »
I'm using 80w90, and it sucks in the cold weather
'04 Mazda 3s 5-door
zoom-zoom
T Biller
Re: Syncromesh
Post by T Biller »
Hi, I found some more info on fluids on a site for a Chrysler that had weak sycromesh from day one on all of them, so I am posting part of it incase anyone else is running into a similar problem.<P>"Many DSMers end up using Redline MTL, BG Synchroshift or GM Synchromesh in their transmissions.  All of these fluids have the same purpose - to increase friction, just as the Mitsu fluid modifier is intended to do.  Most owners report at least some improvement with the new fluids, but most experience significantly better shifting. Opinions and experiences vary. <P>Recent experience suggests that Redline MTL gains in shifting performance by sacrificing synchro longevity. This is not exactly news, but more and more owners are reporting this problem with MTL now that there are alternative fluids available. Many owners considered the tradeoff to be well worth it. However, more people are now recommending a mix of Redline MTL with MT-90 gear oil, to combat both problems at once. "
eunosads
Re: Syncromesh
Post by eunosads »
what if I have this same problem, and no matter what oil I use it doesn't change?<p>I am having my ZE installed in the coming days (ZE is being prepped with cams etc as I type) an I want to know if, while I have the engine etc out, it'd be worthwhile getting the gearbox checked out?<p>It seems that the 2-3 shift has gotten gradually worse since I have had the car.. <p>What do you all think, David? Anyone else?
- EUNOS 30X -
davidosk024
Re: Syncromesh
Post by davidosk024 »
my gearbox has done the same thing... im dropping in my ZE next week, with ECU, LSD. As for cams and stuff im waiting for that, im putting my next chunk of money to exhaust and suspension, wheels and body kit<p>my 2nd gear is rough and so is my 3rd,i find my car runs low on gearbox fluid quickly....
In
Eunos 30x, v6
KL-ZE, 2.5in exhaust, K&N intake
Unichip, LSD, 13lb flywheel, ACT2 clutch, NGK iridium Plugs, Top Gun Leads...<p>Goin In
Cams, Headers, TB, Extractors,
Bored to 2.8, Mazdaspeed Struts, Mazdaspeed strut tops,
Mazdaspeed swaybars, Eibach springs, Cusco Adj. Strut tops, Body kit, Altezza lights, Short shifter, Crossdrilled rotors and Calipers from AP racing, Braided brake lines, Braided clutch line, Mazdaspeed steering wheel, Mazdaspeed Leather shift knob,
David Coleman
Re: Syncromesh
If it stays notchy despite the fluid, its a syncro/slider/gear engagement point problem. Rebuild or replace.
David Coleman
eunosads
Re: Syncromesh
Post by eunosads »
thanks David, much appreciated.. <p>according to my mechanic, it's gunna be like $500 AUD just for the gearbox guys to look at it, and depending on the problem, more to actually fix.. would you say it's worthwhile to check it with the box already out?<p>thanks again...
- EUNOS 30X -
T Biller
Re: Syncromesh
Post by T Biller »
I heard that a stainless clutch flex line helps, if you're pulling the engine anyway though, giver on the box too while it's out. I noticed mine is fine when it's really warm, but sucks in the cold weather. i'm thinking if the rubber hose is a problem, it might be made worse by the fluid getting thick, so I'm gonna try that
eunosads
Re: Syncromesh
Post by eunosads »
I've decided to get the 'box sent off to a specialist to check it out.. <p>I'll also look at getting a s/s clutch line.. <p>I'll let you all know how it goes.. <p>@ds
- EUNOS 30X -
