chirping sound coming from dash
Len-Dogg
Post by Len-Dogg »
I recently developed some kind of chirping sound. It sounds like it's coming from my dash, although I haven't opened the hood up when it's happening to check the engine bay. It sound like a bunch of little birds chirping away when I am idling. It does not happen when I am driving the car, only when it's sitting still idling. Maybe it's just the temp changing around here and the belts are changing a little bit? Not sure. Anyone had this problem?
Thanks,
Jason
1995 Blaze Red RS 5sp. Manual, Pacesetter Exhaust, Custom CAI, 17" ADR Rims, Kumho Tires, Altezzas, GS Style Spoiler and Mud Guards, Neoprene Seat Covers, Aluminum Foot Pedals, Leather Shift Knob, Remote Starter, Blaupunkt Stereo and 5-disc changer, Pioneer Speakers, Amp, and Sub<p>http://www.cardomain.com/id/lendogg<p>http://www.msu.edu/~leonar40/Car.html<p>Image
mx3man83
Re: chirping sound coming from dash
Post by mx3man83 »
Sounds like your belt.
My Cardomain site
wyldside
Post by wyldside »
Actually if it's comming from your dash it's most likely the blower fan for your heater. I hear that sometimes when it's cold. If it's not that then it could be just pastic rubbing. Take you glove box off and have a closer listen.
James Gosteli
X-Prez of MX-West
1992 Seal-Gray MX-3 GSR-ZE (KLZE 2.5L V6) :mrgreen:
1992 White MX-3 GSR-ZE (KLZE 2.5L V6) :( Worklog (Parting out)
1993 Blaze Red MX-3 GS - RIP :cry:
Len-Dogg
Post by Len-Dogg »
Ya, it really sounded like the heater to me too, except that I turned it off and the sound didn't go away. You are right it very well may be something rubbing in the dash, because my car vibrates a ton due to my exhaust. It's a long story. Anyway, if it happens again, I will get out and open the hood and see if I think it's coming from the engine or the dash. Then at least I will know for sure where it's coming from. Once it's warmer, I am hoping everything will expand and fit better, thus less vibration. LOL
Len-Dogg
Post by Len-Dogg »
Ok, well it's definitely not coming from the engine which is a relief. Something in the dash, who knows. Oh well, I don't plan on sitting and idling too much anyway, so I guess I will just deal.
wyldside
Post by wyldside »
I'd also suggest checking the mounting bracket that is holding your deck in place. Sometimes they can loosen up from the weight of your deck bouncing.
James Gosteli
X-Prez of MX-West
Len-Dogg
Post by Len-Dogg »
Here's an update. I have now isolated that this sound only happens when I press the brake in. That's why I only heard it in idle. When I am idling, and I push in the brake, I hear the chirping sound from the dash, and when I let out the brake, it goes away. Stragest thing. Anybody ever hear of this? I will probably just have the belts all tightened or something and I think that might fix it.
wyldside
Post by wyldside »
I still think it's in your dash. When you step on the brake, your car idles differently because of the added electrical load of the brakes and the brake lights, therefor causing a different vibration through your dash board.
James Gosteli
X-Prez of MX-West
Len-Dogg
Post by Len-Dogg »
Ok everyone, basically thanks for the help, and I'm sorry I wasted your time because I found out what it is, and it was my stupid-ness. haha Long story short, my exhaust didn't quite fit right when I put it on, and so it rubs at one point. I put a "patch" there in between the pipe and the underbody of the car to keep it from rubbing, and secured that patch with a hose clamp. Well, all it is is the metal hose clamp rubbing back and forth against the metal of the underbody of the car. No big deal, I will just wrap it or something so that it's not metal on metal contact. I'm so relieved that nothing is actually wrong! Thanks again.<p>Jason
