automatic seatbelts (HELP!)
- Buff1110
okay i got the recall done to both seatbelts on my 92 gs and it fixed the problem temporarily but now theyre horrible. the driver side one locks up a lot and i have to hit it and the passenger one does as well. sometimes i have to restart my car before the belts will even move. also that stupid light on my dash keeps goin on and beeping and i didnt even do anything. im buckled in and if i move an inch itll stop beeping. <BR>any answers will be appreciated.<BR>Dan
Dan
02 Tacoma TRD - Daily
Re: automatic seatbelts (HELP!)
I'd take it back to mazda also. They should not get stuck, that's what the recall was for.<BR>The beeping is a relatively easy fix. It requires cleaning the sensor board on the belt roll under the arm rest and rotating the inner piece behind the sensor board by 10-20 degrees.<BR>
My drivers side seatbelt was broken for like 5 years. I took it to Mazda a couple of weeks ago, and since it had a recall it was free. Works great now. If I were you, I'd take it back and make them fix it.
****F.U.B.A.R. SINCE 03/30/02****<P>Blaze Red w/white racing stripes<BR>FX Designs Body Kit<BR>52" Aerospeed Aluminum Spoiler<BR>18X7.5 Konig Imagine Wheels<BR>Red underbody kit<BR>Blacklights inside
There's a recall on the seatbelts...........NICE! I currently have the fuse pulled from them, since both of my motors don't work. koliveira@genlyte.com <BR>
Do it.......Do it.......<BR>Do it ti'll you're satisfied!
Has anyone swapped to non-Mickey Mouse belts? Complicated? Or easy? Thanks!!
for this seatbelt recall, <BR>how does it work?<BR>i just recently got the car, and the drivers side belt is stock, it's not moving anywhere.<BR>will it be free?
Check out my ride and leave some feedback please!
http://www.cardomain.com/id/mradio007
one more question<BR>here is the link to a website, with all the recalls on 92 mx3 v6, <BR>will I be able to get some of this things done to my car? or since it's 10 year old, it will not apply to it?
i have a 92 they replaced the whole drivers side track for free bout a month ago. as far as i know there is no timelimit on the recal.
-Cody
Green '92 GS
140db on 1 12"
Green '92 GS
140db on 1 12"
