Availabity of ZE parts
So far I have been going back and forth on what to get for my swap, the only reason I watn the 03 is the reliablilty. There are tons of sources, and I think the ZE parts woudl be limited. But can you use basic 03 parts like gaskets/seals/etc. on the ZE? I mean I know the cams and pistons and minfold are a bit different, but isn't it the same block?
Re: Availabity of ZE parts
You can use the same gaskets as a 2.5L Millenia, as it has all the same port sizes.
David Coleman
