engine/tranny swap questions.
Posted: November 22nd, 2001, 2:09 am
by Buff1110
basically i have 2 questions about the different motors n transmissions u can swap into the GS.<BR>1. i understand the klze has higher compression and makes more hp, but is there a big difference between swapping the klze vs. the kl03. (0-60 & 1/4 mile times).<BR>2. i wanna swap the tranny and have found the regular for the klze and also an lsd tranny. what is the difference bc there is a $500 difference. will the lsd make a bigger difference vs. the klze tranny??<BR>any comments will help<BR>Thanks <BR>Dan
Re: engine/tranny swap questions.
Posted: November 22nd, 2001, 10:47 pm
by white fish
03 has 160hp the ZE has 200hp so yeah the ZE has better time but you have to think about the cost difference<P><BR>go for the lsd! what are you paying for it?
Posted: November 23rd, 2001, 12:30 am
by Buff1110
the prices i have gotten so far are<BR>kl03 750<BR>klze 1300<BR>reg tranny 450<BR>lsd tranny 900<P>but how does the lsd tranny differ? and how big of a difference in the ze vs. 03?<BR>Dan
Posted: November 23rd, 2001, 12:56 am
by RayRay
hey buff, where are you getting ur prices? i'm curious cuz i live in nj too. i noticed in ur profile u work at an applebee's too.
Posted: November 23rd, 2001, 10:52 pm
by white fish
lsd stands for limited slip differential (sp) that means when you hit it of the start both wheels will spin rather than just one and belive me you will spin the tires like crazy if you want
Posted: November 24th, 2001, 4:14 pm
by Zoso124
Well first off there is no such thing as a KL03, its just a KL, add the ZE to it (KL-ZE)for it to be understood as J-Spec.<P>Secondly, you don't need the regular tranny cause its the same as the one in your car now, except for a little difference in 5th gear which will make no difference at all to you.<P>Thirdly, the axles are a different size for the LSD and are no not the same as the ones in your MX-3 now. They never tell you that you need to make custom axles because at the moment there isn't any known axles that will work. If there is I would like to know.<P>Good luck! <BR>
<p>[ November 24, 2001: Message edited by: Zoso124 ]
