loud Rumbling sound from around back area
A.S.
Post by A.S. »
I hear a loud rumbling sound when the car is in 2nd/3rd gear. It goes away in top highway speeds and when in gear 1. (The muffler is new) so I doubt its the muffler.
hi
Kim 95' V6 DK
Re: loud Rumbling sound from around back area
Post by Kim 95' V6 DK »
it could be the muffler. <BR>a buddy of mine had the same prob. when his car was warm<BR>cuz when the muffler gets hot it also gets bigger and then it could rub against something under your car especialley when shifting gear (take a look at the engine when putting it into gear moves alot)
<I>Why get a car whith more than two doors when your not running a daytime kindergarten</I>
supercharged
Post by supercharged »
Do you have sub woofers?<BR>The bass might be hitting at the exact time that you shift.<P>Either that or youre dragging a small woodland creature, and the 2-3 shift is whats killing it.
A.S.
Post by A.S. »
I do, but the sound is there even when the subs are off. It is starting to sound like a hole in the muffler. I'll have to go under and look.
hi
