Valve Gasket Leakage
jspicoli
Post by jspicoli »
I just noticed a lot of oil around my spark plugs, and think the valve gasket is shot. Has anyone had this problem and is it easy to fix on your own?
RayRay
Re: Valve Gasket Leakage
Post by RayRay »
i replaced my valve cover gasket, distrib. cap and wires back in january. the valve cover job alone was about $400 usd. see if you can do it yourself, you'll probably save alot.
2005 Nissan 350z
1990 Mustang GT - [sold]
1992 Mx-3 GS - [sold]
mitmaks
Post by mitmaks »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by RayRay:<BR><STRONG>i replaced my valve cover gasket, distrib. cap and wires back in january. the valve cover job alone was about $400 usd. see if you can do it yourself, you'll probably save alot.</STRONG><HR></BLOCKQUOTE><P>$400 just for replacement of head gasket?
back alley
Post by back alley »
i just had the front and rear valve cover gaskets changed. front cost $88.parts and lobour - rear cost $256. parts and labour. i was told the rear is more cramped and harder to access ie.more costly.
