Kl -ze quesiton
Kl -ze quesiton
ok I have a Kl-ze in my car and know I'm hooking up all the wires I'm using the wiring harness that came with the motor and there is a 12 pin female connector if anyoone who has done a kl-ze swap could help me thanks
Re: Kl -ze quesiton
wut the hell is ur question???
Re: Kl -ze quesiton
I don't know where the 12 pin female connector plugs into
Re: Kl -ze quesiton
Where is the 12 pin connector, what is it close to?<P>You didn't label the wires?
