BPD engine GT-R 210hp vs 2.5 KL-ZE 200hp !
Someone know the difference of the performance of this two motor stock ???<P>- 4 cyl. 1.8 BPD turbo engine GT-R 210hp<BR>- V6 2.5 KL-ZE 200hp !<P>The best one is ???????
_ ______________________________ _
MX-3 2.5 KL-ZE, kl-36 ECU, Millenia Intake, Outlaw Phenolic Spacer, Custom CAI, Catco 2 1/2 Hi-Flow Cat, Dual Megan Muffler, Mx3 Flywheel, Rear Strut Bar, Unorthodox UDP, Pacesetter Short Shifter, Cross Drilled Front Disk, Tokiko Blue Shock, H&R Coil, 17 inch white Motegie MR7 with Toyo Tire, Blue Metalic and Full Body Kit.......etc.....
14.61@97 MPH
14.61@97 MPH
Re: BPD engine GT-R 210hp vs 2.5 KL-ZE 200hp !
Well, that depends on what you've got. If you have the Stock 1.8L V6, then get the KL-ZE. If you have the 4-cylinder, get the BPD. Its very hard to swich from the 4 to the 6, or vice versa, although not impossible. the reason why the BPD has such high HP is because its a turbo. This makes it more expensive. I don't think the 10hp is that big of a deal if you've got a V6 already--its not worth the hassle. But its your descision if you want a tubo that badly.
Dude.
And an other thing w/ the KL is that you can still add a turbo or a supercharger so de 25l V6 as more potential. ![Very Happy :D](./images/smilies/icon_biggrin.gif)
Jonathan Michaud
93 Red RS
93 Red RS
